Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Aftermarket Stereo In my 04 questions
Old Feb 17, 2013 | 09:11 PM
mdivanna's Avatar
mdivanna
I was sold when i didn't have to ship you my bezel, also i like the carbon fiber, can you provide me with any info about bypassing the amp?
Old Feb 17, 2013 | 09:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can buy an amp bypass kit for around $30 or buy a roll of speaker wire and run new wire to the doors. Your choice, both work
Old Feb 17, 2013 | 09:17 PM
mdivanna's Avatar
mdivanna
the bypass kit sounds better, im just unclear on exactly how the bypass and steering wheel interface hooks to the head unit. and does the byass harness plug from the HU to the harness on the factory amp? is there more than one harness on the factory amp? ( i could only see one with out taking my dash apart)
Old Feb 17, 2013 | 09:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The aftermarket harness connects to the bypass harness which connects to the trucks OEM radio harness
Old Feb 17, 2013 | 09:23 PM
mdivanna's Avatar
mdivanna
ok gotcha thanks, ill send you a message when i go to order my bezel.
Old Feb 17, 2013 | 09:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
usually, instead of going through all that work, to me, its just easier to run new speaker wire from the new HU harness to the doors
Old Feb 17, 2013 | 09:29 PM
mdivanna's Avatar
mdivanna
that seems like alot of wires to run though if the harness just plugs into everything without splicing, also i didnt like the fact the harness it almost 17feet long, and i dont need that kind of length if all that will be under my dash
Old Feb 17, 2013 | 09:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
No worries, like I said, either way will work
