Connecting stock UConnect Microphone to A/M Radio
Subscribe
Mar 15, 2013 | 12:57 PM
New here, so please be gentle. I did a few searches with no luck.
I have a basic UConnect Radio in my 2012 Caravan that utilizes the microphone in the rearview mirror. It looks like the connection for the microphone is a square gray connector with 3 wires coming out. I would like to use the stock micrphone with my aftermarket radio. Any idea what the wiring is for the 3 wires. I am thinking micrphone +/- and then maybe power for autodimming mirror. But at a loss.
Thanks in advance for any advice.
Reply 0
Mar 18, 2013 | 12:46 PM
are yoou talking about the gray connector on the radio? If so, then that iisn't the mic wiring. That is the audio lines from the Uconnect module.
Quote: New here, so please be gentle. I did a few searches with no luck.
Reply 0
Mar 19, 2013 | 10:18 AM
HI XSDBS,
Thanks for the response. It is a square gray connector with 3 Green/other color wires coming out of it. I assumed it was the microphone connections. If not can you tell me where the microphone connections are located please.
Thanks
Reply 0
Mar 19, 2013 | 11:46 AM
The gray 10 pin connector on the radio is for the audio signal from the Uconnect module.
The mic wires are directly at the Uconnect module 22 pin connector:
pin # 16 = mic (+)
pin # 17 + mic (-)
pin # 18 = mic shield
Thanks
Reply 0
Mar 20, 2013 | 03:55 PM
Quote: The gray 10 pin connector on the radio is for the audio signal from the Uconnect module.
pin # 16 = mic (+)
pin # 17 + mic (-)
Checked both sides of the 22 pin connector, there is no wiring for pins 16-18.
Still not sure where the microphone connects.
This is the basic UConnect radio, no big LCD screen, and a single CD slot.
Any help would be appreciated.
Thanks
Scott
Reply 0
Mar 21, 2013 | 10:23 AM
This is because you're looking at the radio connectors and not the Uconnect module itself. The Uconnect for this radio is an external unit, separate of the radio. I believe that it's located on the drivers side of the dash structure. If you drop the knee bolster and look above the e-brake pedal, you should see a black module about 4" x 6" and look similar to the one pictured below. (the label PN may be different but the module will look the same). There will be a 22 pin, 10 pin connector and a mini USB attached to it.
Quote: Checked both sides of the 22 pin connector, there is no wiring for pins 16-18.
Thanks
Scott
Reply 0
Mar 21, 2013 | 03:24 PM
Quote: This is because you're looking at the radio connectors and not the Uconnect module itself. The Uconnect for this radio is an external unit, separate of the radio. I believe that it's located on the drivers side of the dash structure. If you drop the knee bolster and look above the e-brake pedal, you should see a black module about 4" x 6" and look similar to the one pictured below. (the label PN may be different but the module will look the same). There will be a 22 pin, 10 pin connector and a mini USB attached to it.
Thanks XSDBS,
I will check it out. Thanks for the patience and the information.
Reply 0
Mar 25, 2013 | 09:23 AM
No problem.
Reply 0
Subscribe
