Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
speakers won't work
Old May 10, 2013 | 07:16 PM
StuartReynolds's Avatar
StuartReynolds
Default speakers won't work
I put a pioneer stereo in my 2003 dodge Durango. I used a harness plug to hook up the stock speaker system but it won't work. I know it's wired correctly as I checked it. Is there some amp that needs to be powered up? I've installed literally hundreds of stereos in other vehicles so I'm not a novice. This is the first later model Dodge I've worked on and I know these things are always a learning experience. Can anyone help?
Old Jun 15, 2013 | 11:26 PM
Jdahlberg17's Avatar
Jdahlberg17
same thing is happening to my 1999 Durango slt with the infinity system im trying to put a pioneer stereo in! im not sure what to do with this because the stereo powers on!
Old Jun 15, 2013 | 11:32 PM
01SilverCC's Avatar
01SilverCC
You need to connect the blue/white wire from the Pioneer deck to the solid blue wire in the harness you wired up. The blue wire is for the factory Infinity amplifier remote on. Without that wire being connected, the amp will not turn on so that's why there is no sound.
Jimmy
