Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stock Radio Removal?
Old Oct 28, 2005 | 12:17 AM
Smokin_Joe's Avatar
Smokin_Joe
Default Stock Radio Removal?
How do I remove the Radio in a 99 Dakota? I need to get to the remote wire to tap for an amp.
Thanks, ALSO, does anyone knwo the colors of the Pos. and Neg. wire for the two rear speakers? Thanks.
Old Oct 28, 2005 | 01:52 AM
pimped_neon_RT's Avatar
pimped_neon_RT
Default RE: Stock Radio Removal?
You have to take the hole dash peice off that goes around the radio and the gauges and ever thing. It should just pop off theres just lil pins holding it. the wires should be labeled right on the wire in tiny writing?
Old Oct 28, 2005 | 02:46 AM
Natedogg625's Avatar
Natedogg625
If its anything like my 2001 dak, then all you have to do is remove the lower dash piece. There are 3 screws holid it in than it just pulls out. The main dash board has 2 screws above the gauges, remove these and pull. disconnect all the wires and lift it out. That should be it. I have done it 3-4 times in my truck and its fairly easy. GOOD LUCK
