Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Radio Problem
Old Apr 30, 2023 | 07:48 PM
chrand's Avatar
chrand
Default Radio Problem
I have an 88 W250 that has problems with the radio. The radio is getting power, as I can turn it on and change frequencies. However, the volume switch does not work when I move it up or down. What do I need to do for this?
Old May 1, 2023 | 07:46 AM
Is it the stock radio? It is over 30 years old, might be time for an upgrade.
Old May 1, 2023 | 09:26 AM
chrand's Avatar
chrand
Yea it is. Where can I buy one and which one should I get?
Old May 2, 2023 | 07:08 AM
ol' grouch's Avatar
ol' grouch
There are lot's of aftermarket radios available. You can take your pick. A single DIN will fit just fine. Just be sure to get an installation kit and a wiring adapter. These will make installation easy and you won't butcher your wiring. Walmart, Crutchfield local audio shops can all sell you a radio. Ebay even has them. There are quite a few that don't have CD players but I like to get them with them. There are also a bunch with USB ports where you can load your music on a thumb drive.
If you want a stock radio, Ma Mopar used the same units up to around the year 2000-2001. Look around salvage yards and they don't usually pull those radios and you can get them with ape decks and, or, CD players.
Old May 2, 2023 | 07:11 AM
What he said....^^
