Front door speakers don't work
Hello everyone..
I'm new here and was wondering if you guys could help me out. I have a 2000 stratus ES model I recently installed a JVC head unit (are JVC Head units good?) anyways, once I installed the jvc head unit, my front door speakers don't work. Yet the speakers worked just fine when I had the stock radio. I noticed that the previous owner put some speaker wire on them probably because he/she came across the same problem. I tried putting the speaker wire together with the ones for the front channels on the wire harness.... when I touch the wires, the front speakers come on... the moment I turn the volume ***, the entire sound goes dead. To get it to work, I take the extra speaker wires off. i'm wondering if the extra speaker wires are a problem or if there is a way I can put them to good use...... can anyone tell me how I can get all my speakers to work. I would trully appreciate it... thanks
P.S. Heres a dumb question, just to be 100% sure... in the speaker wire, the two colors where clear and blue. which is ground and which is positive? or does it make a difference?... thanks again.
one way to do it is to run an amp and run all new wires to your speakers. but if your gonna run an amp you might as well get some better speakers if they arent already aftermarket. as far as the colors you would have to find out which one is connected to ground. if its not connected then you can make either color ground as long as you remember which one it is. just to try it i would run my own wires to the speakers off the deck, that way you know that the wires are good. try that first before you go off and buy amps and speakers.
ORIGINAL: moparman04
THAT MUST BE AUDIOBAHN WIRE YOU GOT ... BLUE IS NEGATIVE CLEAR IS POSITIVE ... HOPE THAT HELPS
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
