Rattling problem need help!
I have a 98 Dodge Neon and just got a Rockford Fosgate setup last weekend, it consists of two 12" P1 subs in an enclosed box and Rockford Fosgate P2002 amp. I have the subs in the trunk facing towards the rear of the car and the amp mounted on one of my fold down back seats. The problem is that my rear view mirror rattles to the bass but if I hold it it stops so I'm wondering if there is anything I can do to the rear view mirror to make it stop rattling? I was thinking about just taking it off but I tend to use it alot while driving so I don't know. Also my trunk rattles alot as well. I've adjusted the latch on it but it still does it. What can I do to stop the rattle, can I just put in some mat or will that work?
When I used to have my 98 neon I had the same problem with the mirror, car was totaled before I ever found a way to stop it, my guess it's just the factory mirrors they put in the neons, posibly an aftermarket mirror might not rattle, I know neither of my cars after the neon had that issue, as for the truck dynamat should stop or reduce the rattling.
You will have to excuse me but im not a big fan of fosgate, but that is not what we are talking about. would suggest any kind of sound dampening material for the trunk. dynamat is good and there are others out there too! your mirror, there is no hope for that. just get used to lookin a blurry images behind you. youll eventually get to know whether there is a cop behind you or not, lol. you might also put some on your license plate.
I constantly have to tighten the mounting screw. I even tried locktight blue, but it vibs still. Most times the problem is that the mounting method of the ball isnt tight. One option is to set the mirror and then through in some epoxy where the ball and the shaft meet. If the problem is the mounting screw, there isnt much to be done other than to keep tightening it. I even had the mirror pop off during a db dragrace, got a few "wows" but a pain since I didnt have an allen wrench to tighten it there on the ride home and got a headache from seeing a blurry pic ahah.
