Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
MY JL W6's!!! HELP ME!!! AHHH!!!
Old May 8, 2006 | 08:50 PM
car_audio_god's Avatar
car_audio_god
Default RE: MY JL W6's!!! HELP ME!!! AHHH!!!
Incorrect.
You are going to want either a MONO amplifier, that produces 800rms @1ohm... OR a 2channel amplifier that produces 800rms @4ohms bridged
For inexpensive amplifiers, that still put out great power...
Look into:
Phoenix Gold Xenon
Orion
Hifonics
You could also look into:
Alpine MRP
Rockford Power Series
Kicker ZX Series or SX Series
Old May 9, 2006 | 04:53 PM
HighDuke1911's Avatar
HighDuke1911
i am really looking for 1 amp that will power both subs. so god, then you are saying that one of those amps at 800rms@1 ohm or a 2 channel at 800rms @ 4 ohms can power 2 of my jl's? what do you think of the Rockford P8004?
Old May 9, 2006 | 05:24 PM
habeba86's Avatar
habeba86
That rockford is pretty nice. Expensive tho. http://www.discountjungle.net/produc...er_raa2400.htm that is a very nice amp and very very good price...wow!! I would personally tell you to get a mono amp, but that choice is all up to you.
Old May 10, 2006 | 04:06 AM
HighDuke1911
so a mono amp can power both of my W6's? ok, if somebody could plz tell me what ONE amp can power both of my subs that would be so greatly appreciated! But first, i would like ot thank all the feedback i'm getting. but i canb only fit 1 amp in my truck and need to find out which ONE amp can power the subs! Thanks!
Old May 10, 2006 | 06:41 AM
habeba86's Avatar
habeba86
Either amp with power both subs. Either get a mono thats rated 800rms at 1ohm or a 2 channel amp that is rated 800rms at 4ohm bridged(mono). What amp you get it totally up to you. Class d is more efficient, so it is a little easier on your electrical system.
Old May 11, 2006 | 01:38 AM
HighDuke1911
What about 2 of these? 1 amp per sub?
http://www.onlinecarstereo.com/CarAu...roductID=16412
Old May 11, 2006 | 02:22 AM
forbidden's Avatar
forbidden
I encourage you to look closely at my last post. Your only possible options to get maximum output from the speakers that you have is to wire one of two ways.
A all parallel configuration will yield a 1 ohm mono load with a pair of dvc 4 ohm subs. The proper amp for this is a 1 ohm mono capable and engineered amp. YES the JL / series of amplifiers will work for you, in particular the 1000/1.
The other option is a monster 2 channel amplifer. To use this amp it needs to be bridged mono. You will need to wire the subs in a series / parallel circuit to yeild a 4 ohm load that is safe for the amp to handle.
I gave you links that you may have overlooked, again read the links as they are highly important to your understanding of how things work. If you need I will be glad to answer more questions as it pertains to what you are after.
In most but not all cases, a 4 channel amplifier is not going to be the best choice for you at all.
Old May 11, 2006 | 02:28 AM
forbidden's Avatar
forbidden
I will also not recommend the dual amp route for you at all at this point in time. No offence intended but if one does not understand the basics of electricity and wiring, I would not expect one to understand the complexity of using two amplifiers properly in this application.
Old May 11, 2006 | 03:51 AM
habeba86's Avatar
habeba86
I agree 100% with forbidden. Plus you would have to buy more rca's, distribution block, blah blah. Get the mono amp!
Old May 14, 2006 | 03:31 AM
car_audio_god
ORIGINAL: HighDuke1911
No, as stated... a four channel amplifier will not work to power your subwoofers.
One mono, or one larger two channel would be best.
ORIGINAL: habeba86
VERY solid choice, I would recommend this amplifier.
Stick with one amp as stated, it's a cheaper solution as well.
The above MB Quart amp is of great quality, and will put out it's rated RMS power
