Trouble with hooking up new Headunit
No... I don't, but if I just strip part of the wire and then touch them, that should make it work, if it doesn't I can just solder it back up... and try another right? it won't make anything stop working will it?
All right, I figured it all out, you just have to run your remote wire to the POWER ANTENNA when you wire the harness from your aftermarket headunit to the harness you buy. then when you plug in your harness to your stock one they your remote lines up with the green/red wire which is radio on out. Then viola! you have just hooked up your stock infinity amp. THanks for the help habeba I really appreciate it. I don't know why that didn't click to me the radio on out, duh... that's the only one that makes sense... thanks though.
