Can I put a 10" sub in the compartment under my rear bench (92 Dakota)?
I have an ACI sub that is in a custom enclosure right now. It sounds good, but I want to free up space in the interior. I am thinking of taking the hatch off of the passangers side compartment under the rear bench & putting plexiglass in its place with the sub mounted to it. Will this sound good, or sound like ****? The only problem I see is that the sub will have to push thru the seat cushon.
I can help you if u could please send me a pic of it... Also do you think you can get an idea of exactly how much interior volume there is in that space...
Also no do not put a piece of Plexi over that and mount a sub that would #1 sound like crap... #2 crack...#3 is going to leak... Your best bet is to Fiberglass a mold of that space area and then take it out and then fiberglass around the mold with a fabbed up speaker ring and then give the speaker enough room for linear movement. Best to give it at least 2-3 inches of clearence depending on what hte xmax of your sub is.
You can PM any time if u need some help
