Wiring
Anyone ever seen any good write-ups on how to wire in new electrical item in your car. I usually just splice into other wires, but that is sloppy, so I want to know how to tie into the fuse box the correct way. Thanks.
Ok, here is the first thing I am installing. More items to come later, but hope to get this one done this weekend.
http://www.splitsec.com/products/arm1/arm1ds.htm
Like I said, I have wired lots of stuff already (gauges, lights, etc...), just never connected straight to the fuse box before, always just spliced in to other wires. I think I might just use a fuse connector that allows you to connect a wire into the fuse box using a fuse shaped adapter. What do you think.
Thanks for any help you can give.
