removing head unit in 03
can someone toss me some instructions to remove the stock tape deck in my 03 and what tools i'll need. haven't been able to find anything. thanks for the help.
its prolly the same procedure for all rams... I would think that the Molding that is on the dash face has to come off... thats how i got mine off. Let me check some Int pics and i ll get back to ya
Pulll off that plastic piece around the air controlls and stock HU... Prolly have to pry it off with a flathead screwdriver... then im sure they use the Black Phillips head screws to get it out
The plastic around the radio and climate control ***** has to be popped off. It should jst pop rite off with a little force. The radio will be held in place by a few bolts and will jst come rite out from there. Bend the tabs on the aftermarket units cage so its firmly held into place in the dash kit you bought. Screw in the dash kit, connect the harness into the cd player and lock the unit into the cage, put the plastic back on and your done.
