2006 dodge ram /////jl audio subs?
Nov 8, 2006 | 03:02 AM
hey guys i have a 2006 dodge ram quad cam, i got a eclipse hu and jl w6 10" in a "hot box" from ebay.......well i was looking for more bass?
so my question is whats a good spot for another box??
Nov 8, 2006 | 05:29 AM
RE: 2006 dodge ram /////jl audio subs?
Where is the hot box located?
Nov 9, 2006 | 02:06 AM
Nov 9, 2006 | 06:50 AM
Most ppl with extended cab rams put a box under the back seat. You can find a handful of manuf. that makes these boxes.
Nov 10, 2006 | 03:17 AM
What amp are you running? The W6 can handle quit a bit of power. Also is it an older W6 or the newer version?
Nov 10, 2006 | 05:52 AM
its a newer W6 and im using a alpine amp its putting out 400...
Nov 10, 2006 | 03:20 PM
What model # on the alpine amp? It really sounds like you dont have enough power for your sub.
Nov 10, 2006 | 04:01 PM
The model # is MRP-M450
what amp would u guys recomend?
Nov 10, 2006 | 05:32 PM
Well going off the specs of the Alpine wich I just looked up,it sayd that it will do 400 watts @ 2 ohm which should be somewhat efficient for that sub as long as you have it wired in parrallel (positive to positive and negative to negative).But as far as recommended amp I would suggest the JL 500/1 honestly.
Nov 11, 2006 | 02:45 AM
If it was wired in parrallel it would have got 400 and that is a fine amount of power...
