Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
radio power problem
Old Dec 3, 2006 | 02:08 AM
biggun_00's Avatar
biggun_00
Default radio power problem
I installed an aftermarket head unit in my 2006 mega cab and the only way i could get it to work was power it constantly, read a few things scattered around on here and wondered what a ?can-bus? adapter is and someone aslo suggested to power the unit off the cigarette lighter because it is a switched source. Has anyone tried the latter and if so had any trouble with it? Any info appreciated!!!!
Old Dec 3, 2006 | 02:23 AM
djeazie's Avatar
djeazie
Default RE: radio power problem
I wired my h/u to the cig. lighter and it works just fine!
Old Dec 3, 2006 | 01:16 PM
rtkota5point9's Avatar
rtkota5point9
Yeah with the CanBus systems there is no switched power source to the factory radio. It's done a different way. So you need to run the red accesorry wire to aswitched power source. Cig lighter should work just fine.
Old Dec 4, 2006 | 04:43 AM
habeba86's Avatar
habeba86
Can-Bus sux!!!!!!!!!!!!!
Old Dec 4, 2006 | 01:00 PM
rtkota5point9
ha ha yup!! So does GM's Data-Bus daignostics bullsh*t radios!! [:@]
