Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Radio Problems 2000 Durango, HELP!!!
Old Dec 20, 2006 | 11:01 PM
du24pont24's Avatar
du24pont24
Default Radio Problems 2000 Durango, HELP!!!
I blewa rear speaker and got a replacement, and another replacement, and the rear speakers dont seem to be nearly as loud as the fronts. Anyone have a 2000 Durango to tell me if there rear speakers are not as loud as thefronts??? I have the infinaty 6 speaker system. Thanks everyone!
Old Dec 21, 2006 | 01:04 AM
habeba86's Avatar
habeba86
Default RE: Radio Problems 2000 Durango, HELP!!!
Well they wont sound as loud when are sitting in the front......plus the front is a component set-up, so it will probably be louder than a coxial speaker.
Old Jan 5, 2007 | 02:14 PM
durango360's Avatar
durango360
I know I am a month late on this one, but did you replace the rear speakers with off the shelf store brand speakers? Your factory speakers are 2 ohm speakers and most others are 4 ohm........if this is the case, you may also start to experience some amp overloading and popping......I did exactly that same thing. I have since replaced the rear speakers with Infinity Kappa 62.7i speakers and up front I put in a pair of Infinity Kappa 60.7cs components......they are 2 ohm speakers and sound great.
