Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Wiring Help for new stereo
Old Dec 25, 2006 | 08:57 PM
xbiker15's Avatar
xbiker15
Default Wiring Help for new stereo
NEED HELP ASAP!!!
OK I jsut got a new stereo today and i need some help. The old stereo was aftermarket and it didn't work. All the wires were clipped in the back. I just got a new stereo DVD player for my Truck today and i need some help on the wiring. I need to know ALL the colors for the install. I have msot of them there are jsut a few that i DOn't have. Like where to connect the mute wire and where to connect the ground wire.Are the auto Antenna wire and the Power antenna/amp the same thing? and where does the acc wire on my stereo wire into? Where does the brake wirego into from my stereo?
I found off another post here about most of the colors but there are jsut those few that ihave no idea where they go. I have this so far but i need like 3 more wires.
A Right Rear Spkr (-) Blue w/ White Stripe
Left Rear Spkr (-) Brown w/ Yellow Stripe
Right Front Spkr (+) Purple
Left Front Spkr (+) Dark Green
Right Rear Spkr (+) Blue w/ Orange Stripe
Left Rear Spkr (+) Brown w/ Blue Stripe
Power Antenna/AmpWhite (use for Infinity Radio)
+12 Volt Battery Wire Pink or Pink w/ White Stripe
+12 Volt Ignition Wire Red w/ White Strip
Radio Dimmer Wire Do Not Use
Headlight Dimmer Wire Do Not Use
Right Front Spkr (-) Blue w/ Red Stripe
Left Front Spkr (-) Brown w/ Red Stripe
Old Dec 26, 2006 | 04:16 AM
habeba86's Avatar
habeba86
Default RE: Wiring Help for new stereo
First off what is the vehicle info??
Old Dec 26, 2006 | 04:24 AM
whiteram00's Avatar
whiteram00
first off i would get a wireing harness it would be alot easer
Old Dec 26, 2006 | 04:45 AM
xbiker15's Avatar
xbiker15
ORIGINAL: whiteram00
Ok you must have missed the part about the wires being clipped in the back so i can't just get a wiring harness for it. The truck is a 1996 dodge Ram 1500. I don't think it has the infinity system in it. But the stereo was rippedo ut when i got it so I might. THe question i have is for a DVD player it says i have to connect it to the emergeny brake grounding wire....but how do i Bypass that so i cna watch it on the road? DO i jsut not hook it up?
Old Dec 26, 2006 | 10:51 PM
habeba86's Avatar
habeba86
What model is the unit? You dont have to connect the mute wire and the ground wire jst goes to a good metal surface, you should jst sand it down a bit b4 securing it down. The acc will go to the switching 12 volt/ignition wire(red/white) If you have tweeters in the a-pillar you have the infinity system.
Old Dec 27, 2006 | 02:53 AM
whiteram00's Avatar
whiteram00
my bad i didnt see that
Old Dec 27, 2006 | 06:54 AM
xbiker15's Avatar
xbiker15
ALL IS WELL!!! I installed the new DVD player today. Works perfectly. I also installed new amp and subs while i was at it.Wow i really love my trucknow.It was alright before but now i truly love it. It's nice to finally have a nice vehicle.
Old Dec 27, 2006 | 08:21 PM
habeba86's Avatar
habeba86
Glad is worked out.
