Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
i need help installing new stereo in '04 caravan
Old Dec 26, 2006 | 11:34 PM
hurleykid's Avatar
hurleykid
Default i need help installing new stereo in '04 caravan
i'm installing an aftermarket radio in my friends '04 caravan, and have everything hooked up and working fine, everything with the radio is fine, the only problem is the dashboard/ cluster lights won't turn on now, and i looked into it and saw theres a orange/tan wire that was plugged into the old radio i took out, and its not hooked up to anything now, and I believe it has something to do with the lights, does anybody know what i am supposed to do with this wire? or does anybody know of another solution of why the lights won't turn on.. i've checked the fuses and it doesn't seem to be the problem, there is also a white wire that was originally connected to the old radio, which isn't connected to anything now, and i dont know where it goes, or if it even needed ( i looked around on, and i think its the PCI bus).. please let me know anything you can! thanks alot!
heres the wiring diagram i've been looking at:
http://www.dodge.com/bodybuilder/200...47/8W-47-6.pdf
and i didn't use a wiring harness, i just spliced the wires and connected them that way
Old Dec 27, 2006 | 03:07 AM
whiteram00's Avatar
whiteram00
Default RE: i need help installing new stereo in '04 caravan
buy a wiring harness,saves time an you dont have to try an figure out the factory wires just my 2 cents
Old Dec 27, 2006 | 03:12 AM
hurleykid's Avatar
hurleykid
hey, thanks for the reply, i went and looked at the harness for that type, and even if i went that route, the harness still has a wire coming off it for the dashboard lights, and i still wouldnt know what to do with it, so i'd be in the same position
Old Dec 28, 2006 | 02:01 AM
habeba86's Avatar
habeba86
Yes it looks like the orange/tan wire controls the dash lights....try hooking it up to a switching 12 volt source.
Old Dec 28, 2006 | 06:52 AM
hurleykid's Avatar
hurleykid
hey, thanks alot for the advice, i finally got everything working tonight, it just took a little bit of trial and error.. and yea it turned out the orange/tan wire had to be hooked up to the 12v and also needed to be grounded seperatly.. again thanks!
