Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
06 Ram, adding a double din ?
Old Jan 17, 2007 | 12:53 AM
johnny010's Avatar
johnny010
Default 06 Ram, adding a double din ?
I am wanting to add a double din receiver to my 06 Ram without doing any custom work.
Does anyone know if this is what I need to get the job done?
If not, please share how you all are getting double din receivers into your 2006 & 2007 Dodge Rams that did not come with the factory navigation system.
Thanks again,
John-Michael
Old Jan 17, 2007 | 01:46 AM
rtkota5point9's Avatar
rtkota5point9
Default RE: 06 Ram, adding a double din ?
Yes that's what you need
Old Jan 31, 2007 | 10:30 AM
docsayler's Avatar
docsayler
Your wanting to do something like this?
[IMG]local://upfiles/40597/A5303D2DC04749678C0FF36233462ADA.jpg[/IMG]
[IMG]local://upfiles/40597/A3CE365D885A4C34AE2E80D48BE692B8.jpg[/IMG]
Old Apr 7, 2007 | 03:50 AM
davepier's Avatar
davepier
Docsayler,
That Pioneer nav install is excatly what I would like to do. Is there a kit or instructions available?
Thanks!
Old Apr 7, 2007 | 12:33 PM
rtkota5point9
You'll need the factory Nav Bezel like above, and then the metra double din install kit for a Ram with factory nav (99-6510), because the factory opening is about 1/4" larger all the way around. You'll also need a wiring harness (70-6502) and antenna adapter (40-CR10) That's all you need.
Old Sep 26, 2010 | 01:53 AM
bibalo's Avatar
bibalo
I did a double din install today and everything went just fine except when I hook up my ipod via video cable that I had purchase separately, it keeps skipping, just like an old, scratched up cd. Any thoughts?
Old Oct 6, 2010 | 04:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
no idea but your are not going to get an answer from a thread started back in 07 either. Create your own and new thread if you want some help.
