Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2nd Gen Ram audio design help needed...
Old Mar 4, 2007 | 11:57 AM
BeachCrawler's Avatar
BeachCrawler
Default 2nd Gen Ram audio design help needed...
I could some input on designing a system for 2nd Gen extended cab 1500. I am not looking for a super system. I’d be happy with a middle of the road setup. I got a Jensen DVD setup last Xmas so it has to stay. I know it is the weak link but it was a gift so I must work around it. I currently have the factory Infinity premium 6 speaker setup with the Jensen headunit. The only other thing I have for the system so far is an Infinity 7541a amp that has rme rating of 111x4, 268x2 or 111x2 + 268 x 1 for subs. In the spring I plan to remove the interior and sound-dampen the doors, floor, walls, and roof.
I would like to use the stock locations for the speakers if that will work. So far, I am thinking of using an Infinity 6010cs component set for the front doors and tweeters and using a pair of EDead 7kv.2 7” subs in the rear doors. I am also considering a HotBox under the center console with a 10” sub instead of anything in the rear doors. I’d like the amp mounted under the driver’s seat since I already have 4 gauge cable at my inverter on the passenger side.
7” subs: http://www.edesignaudio.com/edv2/product_info.php?t=0&products_id=33
What would you do AND WHY?
Thanks for the input.
Old Mar 4, 2007 | 07:03 PM
habeba86's Avatar
habeba86
Default RE: 2nd Gen Ram audio design help needed...
I would amp a component system up front, then bridge the other 2 channels and run a 10 in the hot box. Reason being...bcuz I dont care one bit for rear fill. I hate having a surround effect...Front stage is where you get most of your sound from anyway. I also think downfiring subs sound better in our Rams. I would jst run the stock speakers or buy a set of cheaper coaxials in the rear.....Its better to spend a bit more on speakers you get all your detail from, rather spend half to get 2 ok sets. Those infinity are good speakers....I think all Infinity stuff is good quailty stuff. You might also check out ...
http://www.woofersetc.com/index.cfm?...roduct_ID=4331
http://www.woofersetc.com/index.cfm?...roduct_ID=1218
The speakers really depend on you tho, bcuz people's taste on speakers vary widely, but those are good quality sets.
Old Mar 6, 2007 | 11:26 PM
BeachCrawler
Thanks for the help. Thats sound like a good approach. What subs do you like? I totally agree about ignoring therear speakers. The HotBox will save me the trouble of trying to seal the rear doors. I like clean crisp bass. I don't like boomy bass at all. Where would you set the filter for the sub? Since you also have a '99 Ram I hope you can give me a place to start.
Old Mar 7, 2007 | 12:00 AM
habeba86's Avatar
habeba86
I have a 98. Where you set the low pass really depends on how low your front stage can play and personal prefference. But generally most ppl set them at 50-100. Best bet is to mess with it and see where you like it crossed at best. I dont reccomend going above 80 or all the way down to 50tho. I have mine crossed at 68 or something close to that.....
Great sq sub http://www.woofersetc.com/index.cfm?...roduct_ID=2032
Old Mar 7, 2007 | 04:58 PM
BeachCrawler
Thanks again for the continued help. The sub that you suggested looks good. The Hotbox is .65 cf. I will check on the4 ohm version. I've heard nothing but good thiings about ID products. I will try to find them locally and give them a listen.
Old Mar 8, 2007 | 12:09 AM
habeba86's Avatar
habeba86
They are coming out with the version 3 in April....jst incase you wanna wait for the new series. I plan on running 4 of them in my Ram.
