Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
07 ram 2500 wnat to replace the radio
Old Mar 24, 2007 | 02:15 AM
majones15's Avatar
majones15
Default 07 ram 2500 wnat to replace the radio
I just got an 07 ram 2500 that I just love all except the radio, it has the REF radio so I ordered a RAK.
Now I need to install it.
Before I jump in and trash something, is there a pitorial or guide somewhere on how to remove the dash panels and the radio?
If someone could post a link or even suggest a book to buy I would appreciate it.
Old Mar 24, 2007 | 10:32 PM
HI OFCR's Avatar
HI OFCR
Default RE: 07 ram 2500 wnat to replace the radio
www.metralonline.com
You can find the removal instructions on this website.
Old Mar 26, 2007 | 09:49 PM
HaOsLsE's Avatar
HaOsLsE
bad link m8
o i found it...
it's metraonline without the L thanks
Page has a lot of info..but yet to find removal instructions.
***EDIT***
I found it...select make..then in diagram area...there is a PDF file...which shows. THanks m8!!
Old Mar 26, 2007 | 10:48 PM
HaOsLsE's Avatar
HaOsLsE
Wow...2007 dodge was way easy...I went looking for screws..and was like..NO WAY...after I took off 8 screws...for lower panels.
Then I slipped a flathead where the Shiny bezel was...carefully pried..and found...ALL you have to do..is POP bezel out...then the 4 BLACK screws is all you need. The brass colored torx is holding faceplate on the radio..no need to touch them...so POP and 4 screws...If you have an 07 like mine...I just put this in...should have taken me 10 min max...
FYI Sirius...Info # for registering DOES NOT Follow Radio...It is part of the separate Receiver..NOT the in dash. So NO need to call them to change over...I have the same serial # for my Sirius account.
