Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stock CD player with sub install
Old Mar 24, 2007 | 05:38 PM
justinmac86's Avatar
justinmac86
Default Stock CD player with sub install
Ok I just bought a 2003 Dodge Ram QC and I need to get a sub installed but I want to keep everything looking stock and clean so I want to keep the stock CD player but still have a descent 12 inch sub under the rear seat. I've done plenty of sub installs for myself and friends but always with an aftermarket HU so I'm not really sure how to do this. I know it can be done but what is the wire called that you need to get to convert the signal over to subs to make them compatable? And how exactly does it in install? Where can I buy it at? Thanks for all the help.
Old Mar 24, 2007 | 06:09 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: Stock CD player with sub install
It's called a Line-Output Converter and can be had at any car audio shop. It connects to the rear speaker wire's and gives you 1 set of RCA outputs. (4-channel LOC's can be found for a 4-channel amp application also) But you'll need just a basic one. They can be founf starting at about $10-$15 for a basic oneand go up from there for adjustable ones and 4-channel ones.
Old Mar 26, 2007 | 03:05 AM
habeba86's Avatar
habeba86
Or you can get an amp with high level inputs, basically the amp has a built in l.o.c.
Old Mar 26, 2007 | 11:55 AM
rtkota5point9
Good point.
Old Mar 26, 2007 | 07:19 PM
bad venge's Avatar
bad venge
Section Moderator
http://www.reqsound.com/default.aspx I've used these with great results
