Challenger & Barracuda Talk vintage Challenger and 'Cuda (e-body) specific topics within.
Auto to 4speed swap
Old Jul 25, 2007 | 06:56 PM
mjb765's Avatar
mjb765
Default Auto to 4speed swap
I have a 73 challenger that was originally a 4sp and is now a 727 auto. I am interested in putting an A833OD 4 speed back in and was wondering about the shift setup. Is the Overdrive trans the same setup as the regular 4speed?? Will I need to change the driveshaft when removing the auto?? Other than the mount and possibley the driveshaft, are there any other hidden issues I should know about??? Thanks in advance for anybody's assistance.
Old Aug 13, 2007 | 02:44 AM
Battleweary's Avatar
Battleweary
Default RE: Auto to 4speed swap
My guess would be that whoever put the 727 in the car probably shortened the driveshaft to make it fit. I bet you'll need a longer driveshaft. Do you have the clutch linkage that was originally on the car???
Old Aug 13, 2007 | 07:24 AM
mjb765's Avatar
mjb765
The clutch pedal is still in the car as well as the frame mounted Z bar bracket. I need everything else. Since my original post I heard that the driveshaft was the same length. Is that not correct??
Old Feb 12, 2008 | 04:55 PM
dodgebrothers's Avatar
dodgebrothers
I'm not sure of exact length either, but there are multitudes of sources for new and used driveshafts - just check any Mopar mag. You're fortunate that the "tough stuff" is already there, including the pedals (a pain to do), plus you're returning it to what it was originally.
Good luck
Old Mar 20, 2008 | 02:19 AM
JHEMI's Avatar
JHEMI
hey man,
got to hollander interchange.com those good ol' boys are pretty good at that stuff! they have been at it for 30 years that i know of!
jhemi
Old Mar 20, 2008 | 03:26 AM
JHEMI's Avatar
JHEMI
wait a minute,
i put a 3sp standard in my 73 satelite some years back and if i remember right the driveshafts
were the same! and i went fromautomatic to a stick and that was the only part i didn't have to buy was a driveline! or driveshaft!
jhemi
Old Mar 26, 2008 | 11:03 AM
fc7gtx's Avatar
fc7gtx
My 1969 Road Runner was original 4spd car and had a auto in it when I bought it. Later I found a a-833 4spd to put back in it and I used the driveshaft that was already in the car with the automatic. It fit fine. My guess is it may be the same. Wouldn't hurt just to install and check.
Old Mar 26, 2008 | 09:28 PM
JHEMI's Avatar
JHEMI
you could install and check it out probably wouldn't hurt.
do you have all the parts? like the bellhousing/flywheel?
you did mention you had the pedals and some of the clutch linkage.
jhemi
Old Mar 26, 2008 | 11:07 PM
JHEMI's Avatar
JHEMI
hi mjb765,
so in other words you need the rest of the linkage, flywheel,bellhousing,4sp shifter?
if you do decide to do this operation! there is wrecking yard out herethat deals in strictly mopars parts! the place is called wildcat auto wrecking out here in sandy,oregon. there phone# is 503-668-7786 give those good ole' boys a call!
unless you rather have new parts! check your local chrysler dealer.
jhemi
