Challenger & Barracuda Talk vintage Challenger and 'Cuda (e-body) specific topics within.
CHALL/CUDA TRANS SWAP
Old Dec 8, 2005 | 05:12 AM
BURGIEDANNY's Avatar
BURGIEDANNY
Default CHALL/CUDA TRANS SWAP
I have a 73' challenger 360 with a 904 automatic trans. A friend of mine has a 73' barracuda with a 318 and manual trans. I want his trans and he wants mine! Besides the trans hump, what outher issues should I worry about, or should I know before attempting this swap?
Old Dec 9, 2005 | 01:23 AM
TeeWJay426's Avatar
TeeWJay426
Default RE: CHALL/CUDA TRANS SWAP
You'll need to swap the pedal assemblies, all the clutch and transmission linkages and hardware, and the carb linkages as well as the trans hump. Probably the driveshafts of both cars will have to be changed as well- I don't think they can be swapped, as the wheelbases are different between the two cars.
Old Dec 9, 2005 | 03:04 AM
BURGIEDANNY
THANKS FOR THE INFO. DOES ANYONE KNOW IF THE FLOOR PAN IN THE CHALLENGER AND BARRACUDA ARE THE SAME?
Old Jan 24, 2006 | 05:25 PM
brian_a_mcmillen's Avatar
brian_a_mcmillen
All e-bodies have the same type of floor pans however, the 3 and 4 speed types have a wider tunnel. This was actually accomplished at the factory by cutting the tunnel for the automatic trans and welding a boxier and larger one in. You can purchase these on the aftermarket from Jim's Auto Parts, YearOne etc.
