Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
I Need a 1969 318 Engine Rebuild Manual
Old Jun 18, 2007 | 02:38 AM
tom92RTtt's Avatar
tom92RTtt
Default I Need a 1969 318 Engine Rebuild Manual
Recently after long wait I have finally pulled My 1969 Charger from the garage after15 years.
I am in the process of rebuilding and restoring it and need the engine rebuild manual. I am attackiing this project head on the engine is out and apart and surprisingly in great condition.. Any ;eads on where to find this manual would be great and I appreciate all of your help...Thanks alot
Old Jun 23, 2007 | 03:21 AM
tom92RTtt's Avatar
tom92RTtt
Default RE: I Need a 1969 318 Engine Rebuild Manual
now i need to know how you would place the distributor gear on the oil pump drive to correspond to the correct firing order...any help??
Old Jun 23, 2007 | 03:31 AM
Horseapples's Avatar
Horseapples
Use a screw driver to rotate the oil pump drive gear against the cam gears.It will only turn one way,you will notice that the gear rotates out of the cam gear and rises slightly. It can now be rotated to whatever position you want it in. To re insert the drive,simply turn it the other direction untill it drops into the cam gear
Old Jun 23, 2007 | 10:48 AM
HankL's Avatar
HankL
If you sign up for Google email
(Gmail)
and get a password
you can go to Google Books
and read this book for free:
http://books.google.com/books?id=vm_...bFKvnU#PPP1,M1
or buy the book on Amazon for about $18:
http://www.amazon.com/Rebuild-Mopar-.../dp/0895861283
Old Feb 22, 2008 | 11:10 PM
JHEMI's Avatar
JHEMI
hi guys,
haynes automotive manuals or haynes techbooks has a chrysler engine overhual manual that covers all " LA" small blocks from 273-318-340-360 engines, and the"BRB" big blocks FROM 361-383-400-413-426HEMI-440. and also in this book is tha 3.9L mini 318, v-6. the book # is 2114.
it's a good book! and it's the mopar bible! that book is what i go by to seccesfully rebuild, modify,
for race or economy! even what parts thatwill interchange. for performance and economy.
this book walks you thru the process. and alot more!
jhemi
Old Feb 26, 2008 | 09:25 AM
dodgebrothers's Avatar
dodgebrothers
Also try Faxon Auto literature (www.faxonautolit.com)
