Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
66/67 Charger Headlite Motors
Old Dec 1, 2007 | 07:09 PM
strippedhemi's Avatar
strippedhemi
Default 66/67 Charger Headlite Motors
I bought 2 used motors that I knew didnt work for a good price. ($300 ea rebuilt ..EEEK) Usually all they need is the comuntator turned and new brushes, but I cant for the life of me figue out how to take them apart. Manual for 66 Charger only tells you how to swap the motor out. The only screw I can see is holding the grounding wire.
Old Jan 14, 2008 | 12:49 AM
clops79's Avatar
clops79
Default RE: 66/67 Charger Headlite Motors
there are 2 screws,one with ground wire other directly across from it. also half way down motor where the two halves seperate clean out sealer and there is a snap ring that also has to be removed.
