Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
66 Charger, help needed
Old Apr 15, 2008 | 08:51 PM
maverickbb's Avatar
maverickbb
Default 66 Charger, help needed
Please help:
My 1966 service manual tells me the engine is a 361 cu. in. by the 5th digit being an E.[/align]The decode on the Charger registry site tells me a 318.[/align][/align]Also does any one know where the engine is stamped with the serial number on the 318 and the 361.[/align]I am thinking maybe the engine is not the orginal.[/align]Please help,[/align]Thanks,[/align]Bob[/align]Ser. #:[/align]
XP29E61226...
X (Charger)
P (Premium Price Class)
29 (Two door sports roof)
E (318 2bbl 230hp)
6 (1966)
1 (Lynch Road Assembly Plant)
226... (serial # starting 100001)
Old Apr 16, 2008 | 08:32 AM
TeeWJay426's Avatar
TeeWJay426
Default RE: 66 Charger, help needed
E is the VIN code for a 318. F would be for a 361. The engines weren't stamped with the car's serial number until 1969. You should be able to visually tell quickly whether you have a 318 or a 361 in the car. A 66 318 would be a poly version; the distributor is in the back, and the heads and valve covers are visually larger than an LA 318 version (67 & up), with the rocker covers being higher and more squared off, with a raised ridge down the center. A 361 will have the distributor in the front of the engine. Any ID numbers for it should appear in one of two locations; bottom passenger side of the block, near the flange; or the front passenger side of the block. The casting number on a 361 block would be 2205712, which will be the raised numbers on the driver's side of the block. Let us know what you find.
Old Apr 16, 2008 | 08:53 PM
maverickbb's Avatar
maverickbb
Thank you, for your help.
I checked and foundthe stamp on the engine.
It is a318. also I found a stamp on the driver side front block behind the power steering with a stamp P 318.
Thanks,
Bob
Old Apr 18, 2008 | 10:04 PM
maverickbb's Avatar
maverickbb
Thanks,
Bob
