Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
engine codes
Old Oct 30, 2005 | 11:23 PM
68bee383's Avatar
68bee383
Default engine codes
i have these engine codes and i need to know what they mean
4006630-440-8
2468130-3
LL
2468130-9
LL
i found these on the sides of the block any help is welcomed
Old Oct 31, 2005 | 09:47 AM
TeeWJay426's Avatar
TeeWJay426
Default RE: engine codes
They are casting numbers. The first one is for a 1978 440 block; the next two are 383 blocks, from '59 to '71. There should be other codes on the engines that would indicate casting dates, newer ones will have VINs, others will have engine assembly details. If you can get some of those, it will further define what you're looking at.
