Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
'69 RT Charger
Old Feb 7, 2006 | 12:49 AM
ZR900's Avatar
ZR900
Default '69 RT Charger
I just purchased a '69 RT Charger. I will probably have many questions but first, is there any way to tell if it has the original engine? The guy I bought it from is in his 40's and bought the car when he was 17. He "guarantees" it has the original engine and tranny. The rear end was replaced but I did get it with it as well as the original rims. I am inclined to believe him but would like to be sure. Thanks
Old Feb 7, 2006 | 09:27 AM
TeeWJay426's Avatar
TeeWJay426
Default RE: '69 RT Charger
The VIN serial number should be stamped into the engine block, on the right (passenger) side, just above the oil pan. That's the last 6 numbers of the whole VIN; should also be on the fender tag as well. It will also appear on the right front side of the transmission case; it will be stamped someplace in the upper portion of the radiator support; and under the left side trunk weather strip. Check those locations and let us know how you make out!
Old Feb 12, 2006 | 09:25 AM
ZR900's Avatar
ZR900
All the numbers except the tranny match and they are there. Looking for build sheet today.
Old Sep 7, 2012 | 08:37 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Old post, but the R/T would only have a 440 or the 426 Hemi in it.
FF
