Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
67 Dart GT 225 slant 6 engine upgrade
Old Apr 30, 2009 | 04:37 PM
orion20001's Avatar
orion20001
Default 67 Dart GT 225 slant 6 engine upgrade
I have a 225 with a cracked block and I am looking to upgrade to a V8. What would be the easiest and most inexpensive V8 to install requiring the least amount of modifications?
Old Apr 30, 2009 | 07:23 PM
moparborn's Avatar
moparborn
Probably any small block will be about the same $ to swap in.
Old Apr 30, 2009 | 07:27 PM
orion20001's Avatar
orion20001
I have a line on a 75 Dart custom with a 318 rebuild and a new front end is it interchangeable with 1967?
Old May 1, 2009 | 11:43 AM
Horseapples's Avatar
Horseapples
Yes, the engine is interchangeable, however I dont think the v-8 K member will interchange into your 67, but I am not 100% sure on that.
Old May 1, 2009 | 11:35 PM
orion20001's Avatar
orion20001
Thanks for your input, I will check and see if I can get more info on the K member.
Old May 2, 2009 | 12:08 PM
Horseapples
I know there was a change in the Dart's K member and suspension, either 66 or 67. I cant remember which.
Old Jan 5, 2010 | 08:14 PM
Mooman's Avatar
Mooman
Default this might help
Hi, to answer your question it's 67. Darts and valiants were pretty much the same from 64-66. In 67 they changed them. 67-76 are pretty interchangable parts wise so you should be ok. Hope that helps.
Old Jan 5, 2010 | 09:14 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
go with the 340 although a new K member might be needed,
Ff
