Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
Anyone know about manifolds?
Old Jan 2, 2007 | 11:57 PM
crashcaptn's Avatar
crashcaptn
Default Anyone know about manifolds?
I need to know if an intake manifold for a 318 v8 will fit and work for a 273 v8 engine.. anyone know?
Old Jan 3, 2007 | 01:16 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Anyone know about manifolds?
It should, the only differences I know of between small blocks are their bore and stroke, with the exception of the 318 poly block also called 318 wide block which is wider and has it's own unique intake manifold. The big blocks however come in 2 sizes B and RB which changes deck height and requires a spacer to use a B intake on an RB. Check Allpar.com just to be certain.
Old Jan 3, 2007 | 02:58 AM
injmopar's Avatar
injmopar
A 5.2 magnum intake might fit ,but not a 318. The intake bolts on a 273 head go in at the same angle as a magnum.
Old Jan 3, 2007 | 04:04 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
if it is a pre-1994 (non-magnum) 318, it should fit...all of the top end parts are interchangable within reason. unless you have stumbled across something like a W8 intake...
Old Jan 6, 2007 | 06:46 PM
crashcaptn's Avatar
crashcaptn
i know that dodge tried to make an engine with interchangeable parts as much as they could.. and i want a new 4 barrel intake, so its been a pain to figure it all out
Old Jan 13, 2007 | 02:38 PM
unclemike's Avatar
unclemike
Later 273's had the same intake bolt angle as 318 LA motors, I think. Also you will have to watch what manifold you use as the 340/360 heads had larger, taller ports. You can use them but you might have sealing problems plus turbulence at the step down from the runners to the ports. There are used small port 4bbl intakes on Ebay and the Edelbrock Performer is supposed to have a smaller runner.
Old Jan 14, 2007 | 10:58 PM
crashcaptn's Avatar
crashcaptn
i wouldnt mind using the Edelbrock performer at all. i guess i should jsut shoot them a call and see what they come up with.
