Notices
Detailing Discuss detailing your ride inside and out here.
Inside Glass
Old Jan 16, 2008 | 08:39 AM
Brymac76's Avatar
Brymac76
Default Inside Glass
Just curious to see what you all use to clean the insides of your windshields/window glass. I used to use Glass wax back in the day and it rocked,but can't find it anymore.
Most of the spray on cleaners leave streaks (in my opinion) so again..just lookin to see what you all using and what seems works well.......
Thanks in advance.
Mac
Old Jan 16, 2008 | 09:40 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Inside Glass
Stoner invisible glass ,Or the meguiars NXT glass cleaner
Old Jan 21, 2008 | 01:30 PM
heavyk298's Avatar
heavyk298
castle its at advanced auto parts, its about $4 a can, thats the best stuff ive ever used
Old Jan 29, 2008 | 06:40 PM
Bunky's Avatar
Bunky
I use Stoner's too. I use two microfiber towels to clean. One for the first wipe and the second for the final wipe to insure it is dry. I can take several rounds on windows that have a lot of built up outgassing or other grime.
Old Feb 1, 2008 | 12:55 AM
Big Buff's Avatar
Big Buff
If you are not looking to buy something use the home remedy of water and vinegar....it works well... If windows have been cleaned with some type of window cleaner before than just add dish soap to solution... Window cleaners leave very fine film of wax after it is cleaned therefore dish soap will elimate the residue left from the cleaner....
Solution is 2 cups of water, 1/4 cup of white distilled vinegar and 1/2 teaspoon of dish soap....Put in spray bottle...
Hope this helps...
Buff
Old Feb 1, 2008 | 07:16 PM
Quacker's Avatar
Quacker
I'm with bad venge,
Old Feb 4, 2008 | 09:04 PM
02QCGirl's Avatar
02QCGirl
My dad has his own window cleaning business and this is the only way I have ever washed the windows in my vehicles. He does the same with the house windows, his vehicle windows, any glass he cleans...he uses this mixture. Take a clean bucket, put some Dawn dish detergent in and then fill with warm water...make lotsa bubbles....=0] Take an old, 100% cotton sheet, rip it into sections, big enough like a small body towel, have one for the bucket, and one to wipe with. You dont have to wipe hard, unless you are a smoker and have smoke build up to wipe off as well, just wash your window like you would wash your windshield on the outside, then immediately wipe it off with the dry one. You may need several dry ones to wipe with for the whole vehicle, so have several with you. You dont have to soak the window, just wash it, the Dawn will do the cleanin.
I have sworn by this all the years I have been driving....and he's been swearing by it for longer than that. I have also used it on my tinted windows in the cars I had in the past with no damage. Good luck!
Old Feb 10, 2008 | 05:56 PM
06DAKOTA's Avatar
06DAKOTA
finally!!1 i found somethng that will work, and not leave streaks!!!!! thank you 02qcgirl!!!
Old Feb 21, 2008 | 03:54 AM
Night_Runner's Avatar
Night_Runner
stoner invisible glass= no streaks
Old Feb 22, 2008 | 12:53 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i have been using a window cleaner diluted VERY hevily with water (90% or more water) followed by pure water and i dont have a streaking problem, but i think im going to try the mixture recomended above
