Notices
Detailing Discuss detailing your ride inside and out here.
Can power buffer remove scratches??
Old Feb 18, 2008 | 11:41 PM
LBs Laramie's Avatar
LBs Laramie
Default Can power buffer remove scratches??
I'm trying to remove some surface scratches (that haven't gone through the clear coat) and was wondering if a power polisher/buffer is strong enough to do this (whileusing scratch remover)? I was looking at buying a 7" polisher with 3800 random orbits per minute to do this. I'm not sure if I should invest in something more expensive with a more powerful motor/moreamps or should something like this work just fine? Thanks!
Neil O.
Old Feb 25, 2008 | 12:02 AM
rare aries's Avatar
rare aries
Keeper of the Ks
Default RE: Can power buffer remove scratches??
I've always used two products in two steps. The products to use are McGuires Colorx (the rx is the same as a medicine rx) follow the instructions on bottle remove with a clean micro fiber cloth. This is a polish and not a wax, this is not a wax. To wax the area you just polished I use McGuires Gold Class wax again follow directions and remove with a clean micro fiber.
I did this to my Aries, it had fine scratches from the little old lady who owned it before me she would put her hand bag on the roof when she unlocked the doors or on the trunk when she would unlock it.
I hopes this helps.
I would not use a power polisher, because if your not careful you could burn off the paint or leave swirl marks. If you get swirl marks you have to go over it again with swirl remover. I always wax my cars by hand and they look great.
Old Feb 25, 2008 | 10:25 AM
moparborn's Avatar
moparborn
If the vehicle is black,they make special compound for that color because most other compounds will leave swirl marks it the finish.
Old Feb 25, 2008 | 12:09 PM
bad venge's Avatar
bad venge
Section Moderator
If you can feel the scratch with a fingernail it's too deep to buff out ...
can't feel it then you should be able to buff it out
Old Feb 29, 2008 | 11:38 PM
Rampant 150's Avatar
Rampant 150
Another general rule is that if the scratch goes away with a thin layer of water on it, then it should be able to be polished out. Lick your finger and rub it on the scratch. I use cutting compound to remove scratches with a power polisher. This is not a beginners method, and does require using swirl remover to take out the polish marks. On black vehicles I use a 4 step method.
1. Cut polish
2. Synthetic cutting creme (finer cut)
3. 1 step polish and glaze
4. Hand wax
It usually takes about 4 to 6 hours, but will make the vehicle look as good as possible.
Old Apr 22, 2008 | 01:17 AM
khooper's Avatar
khooper
If the damaged area is fairly large or badly damaged, a power buffer may be used with NOVUS No. 2 and No. 3. Use a clean cotton bonnet and operate the buffer at a low speed to avoid overheating the plastic, approximately 1,000 RPM. Each polish should be applied with a seperate, clean bonnet.
___________
Suzuki Muffler
Old Jul 23, 2008 | 04:32 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
ORIGINAL: bad venge
x2
Old Aug 19, 2008 | 02:58 PM
BrienB's Avatar
BrienB
Junior Member
Just giv it a try... I buffed out some of the deepest scratches I had on my car..
Old Sep 17, 2008 | 12:38 PM
Tizi's Avatar
Tizi
I had many fine and not so fine scratches on my 89 Honda. I used this stuff by hand and with a buffer with outstanding results.
http://www.gs-27.com/GS27-Scratch-Re...FQkcHgodgnTDfQ
