Notices
Detailing Discuss detailing your ride inside and out here.
Detailing then Car Cover?
Old Sep 5, 2008 | 02:39 PM
Mumble19's Avatar
Mumble19
New Member
Default Detailing then Car Cover?
I usually get my car detailed once a month and my question is i just got a car cover from carscover.com and i just also got my car detailed...im hearing that you shouldnt put the cover on after detailing? true? im just itching to use the cover to keep the car as clean as possible...help?
Old Sep 5, 2008 | 08:18 PM
bad venge's Avatar
bad venge
Section Moderator
A clean car is the BEST time to use a car cover IMO ... Dirt can be scratched across the car installing and removing the cover
I Prefer this cover : http://www.carcapsule.com/ is it has air blowing it from touching the car
Old Sep 6, 2008 | 05:26 PM
Bunky's Avatar
Bunky
You do have to be careful when using a car cover. It does scratch. My Dakota cover is just to big to manage. I also notice that there is some residue that gets on the truck if left under the cover for any length of time. It would need a wipe down by an exterior detailer to clean it up.
Old Sep 8, 2008 | 11:17 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i cover the demon every night, and the stratus gets covered all winter...when i cover the stratus for winter, before doing so i wash it very well, and put a fresh coat of wax on it. ive noticed that from the wind, the cover "W***les" a bit and leaves ligth scuff marks at a few spots, so where those spots are we have put bedsheets under the cover. the demon cover is so snug that it cant move around, but i do make sure that the car is clean before putting the cover on it.
Old Sep 8, 2008 | 07:33 PM
khooper's Avatar
khooper
i think putting a car cover on the car is not bad because now you won't dare drive it to work and face doing that much work again.
_____________________
Check out ford e350 fuel filter
