Notices
Detailing Discuss detailing your ride inside and out here.
Powder Coat or Paint???
Old Jan 14, 2009 | 05:03 AM
myt69mopar's Avatar
myt69mopar
Unhappy Powder Coat or Paint???
I have a '69 Swinger that is being redone and I'm not sure which route to take with the rear, drive shaft and front suspension. I could have it all powder coated for about 4 bills or should I just paint everything. Just looking for some opinions on what everyone else thinks. I never had anything powder coated and was wondeing if it would hold up better than the paint or would the heat that it uses to coat the parts cause potential damage to them, like the drive shaft and front suspension parts. Any advice would be greatly appeciated.
Old Jan 14, 2009 | 07:38 PM
JimkDaAdtman's Avatar
JimkDaAdtman
it depends on how your using the car... If it's a daily driver, then paint wont last for $h1t.. I would suggest doing color powder coating, Paint will look horrible real fast..
If it's show only, a trailer queen, paint will do nicely..
Old Jan 14, 2009 | 07:47 PM
bad venge's Avatar
bad venge
Section Moderator
Proper masking inside the joint bearing races will keep the proper diameter for the bearings to seat ... As the powder coat can effect that and it's a pain to clean out ...
Old Jan 15, 2009 | 04:36 AM
myt69mopar's Avatar
myt69mopar
OH no, no, no. No trailer queen here. What fun is there looking at a car. Now, grabbing gears and layin' down some ess's... now that's fun! I'll keep in mind about the bearing races too and ask the shop how they'll go about it. Thanks for the input.
Old Jan 15, 2009 | 09:36 AM
bad venge's Avatar
bad venge
Section Moderator
There are plastic plugs that can go in or some just mask off with high seat tape , (as it's baked on at 400 degrees) , Others just wipe off the powder after it's been sprayed, before they go baking ...
Old Jan 30, 2009 | 12:17 AM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah i'd deffinitly go with power coat for what you want to do
Old Jan 31, 2009 | 01:34 AM
Scott91370's Avatar
Scott91370
Powder. It's the only way to do anything that can be baked. Easier to clean too.
