Notices
Detailing Discuss detailing your ride inside and out here.
Removing emblems question
Old Jan 21, 2007 | 01:59 AM
mrclaud's Avatar
mrclaud
Default Removing emblems question
I have a 06 megacab and I would like to remove the emblems (2500, megacab, heavy duty, cummins)from the sides and tailgate.
Does anybody have a idea on how to do this with no damage to the paint? Also are any of them pinned on or do they use epoxy on all of them?
Thanks
Mark
Old Jan 23, 2007 | 04:09 AM
weswing04's Avatar
weswing04
Default RE: Removing emblems question
On my '04, I used fishing line to cut them off (cutting the sticky foam backing), then I used bug and tar remover to get the rest off. Pretty simple process.
As for the 06 having pins or epoxy, I'm not sure...
Old Jan 23, 2007 | 12:07 PM
MoparMJM's Avatar
MoparMJM
ORIGINAL: weswing04
That is exactly what I was going to suggest. It is probably the safest way of doing it.
Old Jan 23, 2007 | 04:29 PM
skate_or_die2008's Avatar
skate_or_die2008
I havent tested it but one of my friends pealed the letters off and used lighter fluid to get the sticky back off i dont know how it works though.
Old Jan 23, 2007 | 05:38 PM
Sinister's Avatar
Sinister
im with the first two,
some type of high tensile string / fishing line
GooGone or similar gunk removal product.
Patience
RazorBlade (lubed) for some chunks you miss.
Old Jan 23, 2007 | 07:38 PM
MoparMJM's Avatar
MoparMJM
ORIGINAL: Sinister
Patience
A small plastic scraper/razor would probably be the best bet
Old Jan 23, 2007 | 07:45 PM
Sinister's Avatar
Sinister
yeah, i suppose, a little more safer to some.
Old Jan 29, 2007 | 06:17 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
use a head gun and slowly peel back on the emblem wash your car before doing this. most of the adheasive backing should come off with the emblem if not heat it up with the heat gun and use a soft cotton glove to roll the rest off wax area when cool after
Old Dec 3, 2007 | 12:31 AM
surferkidd99's Avatar
surferkidd99
i used fishing line (20lb test) to remove my emblems. for the '06 all emblems are mounted with an adhesive.
Old Dec 7, 2007 | 09:07 AM
Night_Runner's Avatar
Night_Runner
so you know, wd40 will probably work better than bug and tar remover. atleast i have found it to work better. and fyi, wd40 will NOT harm your paint. the wd stands for water displacement, and 40 was because it was the 40th formula that they decided to use. it is actually safe on a lot of things. google wd40 uses, there are thousands
