Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Fluid leaks
Old Oct 21, 2010 | 01:46 PM
99-5.9's Avatar
99-5.9
Default Fluid leaks
1999 dodge cummins 5.9, 180k miles, quad cab,
new to the fourm and have a few questions about my truck i hope someone can help with, red fluid that is spraying around where the drive shaft comes out of the transfer case, i was told it was a pinion seal, took it to the dealership, they said it was a normal overflow of some sort, not the seal, then they told me the yoke seal on the rear differential was leaking, but i cannot see any leak coming from this area, and lastly the rear differential is leaking on the back side around the cover, is this just a seal in there? Thanks for any help.
