Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
A/C ports both "large" size diameter ( High?)
Old May 30, 2013 | 10:05 AM
hounds's Avatar
hounds
Default A/C ports both "large" size diameter ( High?)
Ok, before you ask, YES I have checked several times and also took to my mechanic. The truck has Two Ports and they are BOTH larger size so re-charging is impossible.
The truck was re-built pretty much completely it was a salvage and put back together. It it possible someone re-built by accident with both large ports?
SO, question: How can I re-charge it? Home Made Adapter? IS there such a thing I can buy?
thanks
Old May 30, 2013 | 11:30 AM
Jigabop's Avatar
Jigabop
change the low side line out to be the correct line...
Old May 31, 2013 | 07:52 AM
hounds's Avatar
hounds
Thanks. After looking at it, it appears that is fairly easy and straight forward.
Old May 31, 2013 | 01:11 PM
Jigabop's Avatar
Jigabop
might replace the dryer while you are at it...whenever you have the system open, its always a good time to change the dryer...it is basically a filter for the charge system so it's kinda like changing your engine oil filter.. only its an AC part. shouldn't cost much for a new one.
