Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Turn signals stopped working
Old Dec 21, 2017 | 07:24 PM
Rdavid1286's Avatar
Rdavid1286
Default Turn signals stopped working
Maybe I can find a solution here. My turn signals started shorting out about 2 weeks ago. They would internmentaly work and finally a couple days ago just stopped working. I took the entire switch off and checked the wires/connections. As well as the wires all the way down the line for a possible short or tear. I couldn't find anything.
A friend suggested the turn signal relay is what's shorting out or just out all together. However every time I research the part it comes up at the hazard blinking relay (even typing in turn signal relay), Mopar 56007348. The issue is that my wipers and hazards work just fine. Just my blinkers are out.
Would ordering a new hazard relay also fix this issue or is the hazard relay and turn signal relay two different thing?
Old Dec 21, 2017 | 08:11 PM
What are you driving? Year/make/model.
Old Dec 22, 2017 | 10:28 AM
Rdavid1286's Avatar
Rdavid1286
Default 2001 Dodge Ram 2500 24v diesel
It's a 2001 Dodge Ram 2500 diesel 24v
Old Dec 22, 2017 | 10:48 AM
On your truck, hazards and turn signals use the same relay. Replacing it would be a good first step.
Old Dec 22, 2017 | 11:09 AM
Rdavid1286's Avatar
Rdavid1286
Thanks for your help.
