Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
2006 Ram 3500 Mega Cab
Old Nov 5, 2023 | 04:53 PM
sporta's Avatar
sporta
Default 2006 Ram 3500 Mega Cab
Hey all,
My dad has a 2006 Ram 3500 Mega Cab that he is currently running 275/65r18 tires on stock 18" rims. I read someplace that you can run up to a 35" tire without too much hassle, only some slight rubbing at full lock. Is this correct? I found a set of 285/75r18 tires that appear to work but before buying them I want to make sure I'm not setting him up for more problems. According to the tire size comparison chart I found online, the tires are about 2" bigger in diameter (roughly).
Is there any issue running these tires besides the speedo being off?
Thanks in advance
Steve
Old Nov 5, 2023 | 06:03 PM
What gears are in it?
Old Nov 5, 2023 | 06:41 PM
sporta's Avatar
sporta
It has the 11.5 rear axle with 3.73 gearing
Front axle is 5200#
Old Nov 6, 2023 | 08:03 AM
3.73 might be a tad light for 35 inch tires....... getting that much truck moving with big tires, and those gears? You will notice the loss of power..... might be better mileage on the freeway though.
