Daytime running lights Ram 2nd Gen by flintspirit
If your control box for the daytime running lights fail just do what I did.First unplug the harness from the control box which is located on the driver's sideinner fender under the brake master cylinder.Now on the side of the plug that has the locking clip, locate the third hole from the left and the last hole.Make a short jumper wire and use it to connect just these two points. Put some silicon or liquid electrical tape on it to seal it.This will eliminate the daytime running lights but keep the high beam indicater working normaly.There you go, no need to pay big bucks to replace the control box.If you need a better picture to help you don't hesitate to pm or email me and I will clean it up and try to get you a better pic!
[IMG]local://upfiles/15402/0009DE9542CB4902B068CD9DE0F2F09B.jpg[/IMG]
Ram2ndGen
Ram2ndGen
