Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
99 Avenger Problem
Old Dec 9, 2009 | 09:41 PM
Aveng99's Avatar
Aveng99
Default 99 Avenger Problem
i have a 99 avenger and my problem is that my brake light is on....my e-brake is all the way down and it doesn't even work if that matters.... i was thinkin that it was something with the fluid but can't detect any problems... anyone have any ideas
Old Dec 10, 2009 | 10:13 AM
WBattack's Avatar
WBattack
Could be the cable going to the e-brake needs to be looked at. Or if you have rear drum brakes, there might be a problem with the wheel cylinder(s). Just a few suggestions to look at.
Old Dec 10, 2009 | 06:08 PM
bad venge's Avatar
bad venge
Section Moderator
The brake light can be the E brake and also low fluid level in the resevoir , OR even excessively worn brake pads as the you need fluid to push them out further
