Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
2011 avenger help needed
Old Apr 27, 2012 | 08:43 PM
moe-man's Avatar
moe-man
New Member
Default 2011 avenger help needed
Hi guys,Ive got this ongoing problem with the brake lights coming on when you turn the key to start or even in run.using the laptop and pod I can see the pcm is seeing the brake light applied,The abs module is seeing the pedal,same with the cluster.the only module is the tipm that is not reponding.I think its a grounded wire from the abs module to the tipm.any one have this problem?any thoughts?Moe
Old Aug 29, 2012 | 02:37 PM
calvindsouza11's Avatar
calvindsouza11
check with cables or change them if not solved consult any technician he will make it right
