Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
98 avenger stalls when hitting the brakes
Old Aug 22, 2012 | 07:22 PM
misavenger's Avatar
misavenger
Default 98 avenger stalls when hitting the brakes
98 Dodge es 6cyl it stalls when I hit the brakes after I put it on the dyno at about 14 miles, if I shoot starting fluid in the intake it runs but if I hit the brakes again it stalls. Items replaced, distributor, rotor,coolant temp sensor, fuel pump relay and the IAC. I have 55 lbs pressure with the fuel pressure gauge and it stays steady even when it stalls but finally trickles down. Any ideas? Thanks
Old Aug 23, 2012 | 06:01 AM
bad venge's Avatar
bad venge
Section Moderator
Block off the EGR if it then idles you have a bad EGR valve
Old Aug 25, 2012 | 10:12 AM
misavenger's Avatar
misavenger
Is it under the intake or behind it?
Old Aug 25, 2012 | 01:52 PM
misavenger's Avatar
misavenger
Well I replaced the egr and same thing
Old Aug 30, 2012 | 08:22 PM
misavenger's Avatar
misavenger
I guess nobody knows the answer
Old Aug 30, 2012 | 09:48 PM
steak59's Avatar
steak59
crank walk?? auto or stick shifT?
j/k, probably bad IAC motor? bad IAT sensor? what if you apply the brake AND gently apply the gas at the same time to keep it brake torque at 1000 rpm?
Old Aug 31, 2012 | 09:32 AM
misavenger's Avatar
misavenger
Replaced the Iac already, Its an automatic and yes it stalls when you hit the gas and brake
Old Aug 31, 2012 | 06:44 PM
bad venge's Avatar
bad venge
Section Moderator
I HATE trying to troubleshoot things over the internet since you've thrown so many parts you might have added new troubles ...
I said to block off the EGR , this will show if there is air getting in , (not replace the EGR)
you replaced it but it might not be getting the signal to shut off ...
blocking the egr (on passenger side of rear of manifold) make a small metal block off and try it , if the car idles then the EGR is the trouble then you have to check the signals (since you replaced it already)
Old Aug 31, 2012 | 11:44 PM
steak59's Avatar
steak59
It stalls while the car is rolling too? Are you saying the Engine dies as soon as you hit the brake? or because the car is STOPPED at a light?
does it have to be in Gear? or it will stall in neutral too?
this really makes no sense. Maybe your brake electronic is shorted to something? try Disconnect the Brake Switch, now hit the brake, see it it still dies.
Old Sep 1, 2012 | 03:31 AM
Maxweller's Avatar
Maxweller
Well I can only say that if you are having problem with the avenger brakes, make sure that you get a check up of these parts as early as possible. You will get good advice from the dealer.
