Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
dodge avenger rpms fluctuating only when stop
Old Aug 17, 2012 | 10:01 PM
Sammy89's Avatar
Sammy89
Default dodge avenger rpms fluctuating only when stop
my 2000 dodge avenger idles bad only when stopped at a light or just sitting even worse when my ac is on other then that i have 131,000 miles on it, runs great other than this issue with the idle can anyone out there help me. I tool it to a local mechanic and was assured it was the timing belt and It didnt fix it yet i was still out of the money i paid him to fix it.
Old Aug 17, 2012 | 10:29 PM
bad venge's Avatar
bad venge
Section Moderator
Have you tried blocking off the EGR ? bad EGR allows unmetered air in and can cause stalling
Dirty /defective IAC can cause stalling but you replaced it (defective?)
leak in the manifold/ gasket area , throttle body gasket leak ?
Old Aug 17, 2012 | 10:50 PM
steak59's Avatar
steak59
does it ever die out on ur at idle/stop?
Old Aug 18, 2012 | 10:03 AM
Sammy89's Avatar
Sammy89
The mechanic claimed he replaced the egr valve but i would love to block it off I just cant find where its located, is it closer towards the head light or more towards the steering wheel...dumb question but I have no clue.....................and to the other reply i received while im at a light and its dropping sometimes when i hit the gas it does cut off but starts right back up.
Old Aug 18, 2012 | 11:01 AM
steak59's Avatar
steak59
when u hit the gas it dies? kinda do sound like a symptom of jump time. But you alrdy changed it...
Your mechanic should have really check timing before he change it.
It could be a bad Throttle position sensor or Mass Air flow sensor. But those things really need a scanner to check.
Old Aug 18, 2012 | 11:12 AM
Sammy89's Avatar
Sammy89
Yes i agree he should have checked it first needless to say i just filed in small claims court againts him for replacing that and it didnt fix the problem i took it there for, and he refused to mess with it anymore. But ill check on those sensors thanks for the info, My car should be close to new after this not much more i can change on it.
Old Aug 18, 2012 | 01:50 PM
steak59's Avatar
steak59
Sorry for my mistake, i think ur car uses Manifold pressure sensor instead of mass air flow. I was mistaken it from other engine. you have a 2.5l V6, right?
Also want to check Fuel pressure.
But sometimes I see problem with Distributors in those cars as well(freaking expensive part). But this problem, u need a real mechanic. I suggest you just take it to the dealer and pay a little diagnostic fee instead of taking guess.
I hope you can get some money back from ur mechanic. If he refuse to work on ur car anymore and didn't fix it, he should at least give u all labors money back. And just charge you for the parts(which is really not expensive). Generally this is the practice mechanics have in my area.
Old Aug 18, 2012 | 11:32 PM
Sammy89's Avatar
Sammy89
Unhappy Broke down today
well new update on my dodge I was going down the road stopped at a light all of a sudden i hit the gas and the car wouldn't move my motor started making the loudest noise ever and completly shut off in the middle of the road. kept trying to start it back the whole car was shaking while it was trying to turn over every time it turned it wouldn't move just very very loud noises from my motor hitting the gas made it shake harder and louder. Ive never seen anything like this. had to get it towed to dodge dealer today hope it gets fixed now if it is fixable it wont drive at all now......and yes its a 2.5l Have no clue whats going on guess on monday or tuesday they will tell me the damage done now
Old Aug 21, 2012 | 06:24 AM
bad venge's Avatar
bad venge
Section Moderator
EGR 's on the rear of the manifold passenger side two bolts hold it on , a small gasket made out of a tin cans enough to block it off ...
Your update sounds like a timing belt failure that was supposedly just redone
Old Aug 23, 2012 | 10:37 AM
Sammy89's Avatar
Sammy89
well took it to dodge dealership on monday and didnt hear anything from them until wed, they said there not sure what it is...but they think it may be the ignition distributor...OMG this car is costing me soooo much guess we will see if they are right.
