Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
Heater Fan on 1998 Dodge Avenger
Old Nov 23, 2012 | 11:01 AM
dnmcbride's Avatar
dnmcbride
Default Heater Fan on 1998 Dodge Avenger
Heater fan stopped working last nite and only 0 degrees (Alaska). Appears to be power to controls, AC button next to fan control lights up when pushed. However fan does not work at all. Checked fuses and all are good. How do I check for problem? Is there an in-line fuse? Do I take out heater controls from dash, how, and what do I look for? Do I take out fan motor, how, and what do I look for? Any advice appreciated, thanks.
Old Nov 23, 2012 | 10:39 PM
bad venge's Avatar
bad venge
Section Moderator
check power to fan , drop glove box behind it
Old Feb 9, 2013 | 12:51 AM
DSXAvenger's Avatar
DSXAvenger
I had this issue on my 99.
Switched the blower motor out and fixed it np.
Stealership told me 4hour job when in fact I had it out in 10 minutes and the new one installed in 10 minutes lol.
The last bolt @ the back of the blower motor is a pain in the *** to get at.
Very simple job, make sure your power cord isn't loose too before you start swapping parts out.
