Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
96 dodge avenger ES bad EGR volve?
Old Jan 28, 2013 | 05:43 PM
dsexton18's Avatar
dsexton18
The rubber tubs are clear air flows out them. That was the first thing I checked after taking the EGR valve off. Did you have any specific tubes or piping in mid that needs to be checked? other then what I said above? Seams like the next step is to replace the EGR valve. Thoughts?
Old Jan 28, 2013 | 06:09 PM
dsexton18's Avatar
dsexton18
I checked the rubber tubes on the EGR valve and they where fine. No blockage at all. Where their some specific pipes or tubes you suggest I check other then what I checked above? I am thinking it's time to replace the EGR valve. Thoughts?
Old Jan 28, 2013 | 06:37 PM
bad venge's Avatar
bad venge
Section Moderator
have you checked the canistor in the fender wells
Old Jan 28, 2013 | 07:50 PM
dsexton18's Avatar
dsexton18
Dose it look like item 1 in this diagram? http://www.factorychryslerparts.com/...ssembly=536936
Old Jan 28, 2013 | 09:08 PM
dsexton18's Avatar
dsexton18
When you say canister are you talking about the fuel canister or pump canister? Are you suggesting it might be the fuel filter? And not the EGR?
