Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
check engine light
Old May 20, 2015 | 11:58 AM
suzanne02's Avatar
suzanne02
Default check engine light
where is the ecu or ecm located to reset a check engine light on a 1999 dodge adevnger
Old May 20, 2015 | 11:59 AM
suzanne02's Avatar
suzanne02
how do you reset a check engine light
Old May 20, 2015 | 12:04 PM
You need a code scanner to reset a check engine light. You can also try disconnectinfg the battery, but if the condition that caused the light to come on is not corrected, it will come back on. Can you provide some details around the situation?
Old Jan 4, 2020 | 10:17 AM
Dodgevity's Avatar
Dodgevity
You might not even need a code reader if your vehicle can do the key dance. Google it for your vehicle.
