Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
2008 Avenger Battery keeps dieing.
Old Feb 14, 2024 | 04:34 PM
ajdragon's Avatar
ajdragon
Default 2008 Avenger Battery keeps dieing.
Hi
I am working on my sisters 2008 Avenger and the battery keeps dieing I have done some searching and I know about the possible radio problem which dose not seem to be the problem in this case, I have done a parasitic draw test and everything checks out there here is my parasitic draw test you will have to cut and past this to youtube search to view "youtube.com/watch?v=WnM-R92yDTE", I'm getting 14.5v from the alternator, I'm not sure what else to check. If I had the equipment I would do an overnight parasitic draw test to see if something is kicking back on but unfortunately I don't have the equipment.
Old Apr 20, 2024 | 05:23 PM
ajdragon's Avatar
ajdragon
Little update: The radio is the problem, the battery has held a charge for the past two days. I started the car up and it ran just fine, turn the radio on and forgot to turn it off before shutting the car off, and not even 10 minutes later the battery is dead.
How do i fix the radio.
