Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
P0171 p2432
Old Apr 23, 2025 | 08:17 PM
MikeRod1030's Avatar
MikeRod1030
Default P0171 p2432
New to here 😄 Need help … so i just replaced the valve cover gasket and spark plugs and did oil change & ignition coil. Car been needed work but i had it sitting for a little but im driving it now since this car has AC instead of the car I have now. But my problem is I have these 2 codes p0171 p2432 , I’m thinking I have a fuel delivery problem with the code p0171 because everytime I start the car soon as I release key the car just shuts off. Wierd because when I first start car in the mornings it’ll fire right up but soon as I cut it off the car will just cut off go back to ACC mode and I have to re try starting it and hopeing it’s start up. I’m aiming towards fuel problem but I don’t want to just throw parts at it.
the p2432 I know I need to replace the secondary sensor but I been putting that off since that piece is like $225+
any help with this stalling/cut off issue ??
