Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
aftermarket radio install
Old May 16, 2007 | 11:06 PM
focusnme's Avatar
focusnme
Default aftermarket radio install
hey - this is my first post
just got a 2007 dodge caliber sxt sport - with-out the 458 watt system
i am installing a kenwood kvt617-dvd player with touch screen nav and i have found the plastic insert
the question is ........... do i need the chime insert or additional insert for the stereo system??
Old May 17, 2007 | 04:38 PM
focusnme's Avatar
focusnme
Default RE: aftermarket radio install
what no one???
Old May 17, 2007 | 06:16 PM
bigtsr's Avatar
bigtsr
I can't help you with your radio installation but there are a number of Caliber
owners on caliberforums.com or caliberforumz.com who have done quite
few,maybe you should post there.
Old May 20, 2007 | 03:35 PM
caliberlover07's Avatar
caliberlover07
go to www.caliberforumz.com it has alot of info on aftermarket mods.
Old Aug 23, 2007 | 12:40 AM
talon98's Avatar
talon98
If you're installing a nav unit you'll need the differnet dash bezel for the cars that come factory with NAV, The install kit for a caliber w/ factory nav, and either the high dollar power adapter or you can rig one of the older 06+ non canbus plugs to work. If you opt to not buy the 75-125 box for the power plug you will get a check engine light stored in your computer becasue the factory radio is no longer communicating through the bus system. It doesn't set the dash light though, just a stored code saying no coms w/ the radio. Other than that it will work fine.
